Mariner 200hp, no spark.
Asainz320
I have a Mariner outboard which started perfectly on Monday, today when i tried to start it, it wouldn't start. I checked the spark plugs and they didn't spark. I also disconnected the main plug for the wiring harness and turned the engine over and nothing happened, no spark.
What can cause this?
andy6374
Re: Mariner 200hp, no spark.
A sudden loss of spark to all plugs is most likely caused by a faulty kill switch. Disconnect the blk/yel wires at the switchboxes and try again.
Just remember that you won't be able to kill then engine with the blk/yel wires disconnected, instead you'll have to choke it till it dies.
Laddies
Banned
If you have disconnected the blk/yellow wires from the switch boxes and still have no spark then ck the stator, thats probably the problem
Asainz320
But didnt I disconect the kill switch by disconecting the big wiring harness plug at the engine?
Asainz320
What wire should i disconnect. I have three black and yellow wires. I disconnected the three of them and i have spark on one side only. I changed the thing that looks like a power pack and nothing. Does this mean it is the stator?
JUSTINTIME
no
i would recomend a manual
have u tested for cdi output to the coils?
Laddies
Banned
It still sounds like a stator bur just don't throw parts at (that cost to much money) either you test it, have you a OHM meter ot DVA available to you? we can talk you through it or have it tested one or the other, let us Know
Asainz320
Up to now, it hasn't cost me a penny since i have many parts available from other engines i have. Today i did some more testing and i only have spark on cylinder 4. Can this be the switch board? I will be getting a new tester tomorrow since the one i had was left outside and got wet. I checked the coils and they are good too. Im guessing the stator is not the problem since i interchanged the power cables from one switch box to the other and same thing happened.
