Re: mariner 28 fuel ratio/tune up
I highly recommend you get an oem factory manual for your motor, that will give you all the info you need. Also dont spray any thing into the carb but oil fuel mixed. Very bad to spray carb cleaner or starting fluid in there, could cause oil to wash of the cylinder walls and cause premature wear/
