Look familiar?
Looks like it will run around $1200
Specs:
Stealth Stalker 10 Specs
Exterior: 10′ x 5′
Weight: 37.5 lbs (hull only), 78.5 lbs (w/ floorboards & motormount)
Capacity: 2 Adults or 1200 lbs.
Engine Capacity: 4 hp gas (45 lbs. max weight) or up to 74 lb. thrust electric, 15″
shaft
Interior: 7′ 6″ x 2′ 4″
Tube Diameter: 16″
Deflated: 31″ x 40″ x 9″
Chambers: (port side, bow, starboard side)
Material: 1000 Denier 36 mil
Seam: Combination 98% welded with 2% superior glue finish and
quadruple overlapping seams
Floor: 1000 Denier Reinforced
Air Valves: Recessed One Way
Speed Estimates: 5-6 mph w/Gas, 4-5 mph w/Electric
Inflation & Assembly time: 15 min.
Specs:
Exterior: 10′ x 5′
shaft
Tube Diameter: 16″
