mariner 40 question
bb1111
i recently bought a 40hp Mariner and am having a hard time finding any info on the motor. the serial number on it is mariner 40E 6E9 L 405314. Does anyone know where i can find out the year etc. on this motor?
Mike722
Re: mariner 40 question
I use to go to Mercurypartsexpress.com to look up parts for my 1994 Mariner. I am not sure if all Mariners were made by Mercury.
05GlastronSX
i believe it is a 1982 but i am not 100% sure...heres the link but i could not find a perfect match but if you look at 1982, its a 40 EL and similar SN.
40 EL 6E9-402516 through (no info) 1982
http://www.marinshopen.se/ then click modellguide in the top right corner and click the engine make and find the SN.
Texasmark
Well, if it's like the '94 Mariner 40 hp 4 cyl, it's the 44 cu in block with cross flow fuel scavenging Merc built since the '50's with upgrades over the years like going from the magneto (don't know year) to all solid state ignition, using stainless steel for prop and drive shafts, improved water pumps and things like that.
Should be a rock solid performer.
Mark
