Mariner 40hp warning sound
artur.filipe
Does anyone know what can be the problem with my 6-year-old 40hp 2 stroke mariner outboard? After some (few) minutes, the warning sound from the QuickSilver control commands starts screaming and the engine lowers the rotations and shakes very much! If I turn it off and start it again it will continues for a couple of minutes, until it starts all over again. This happened two years ago and, as it appeared, it ended suddenly . The weather keeps running from the cooling system, oil level is full, red light in the engine is off, and nothing is obstructing the water in holes. If I keep it on very low rotations, it woks just fine but when I speed up a little…<br />Could it be some thing with the valvoline levels in the columm?<br /> artur.filipe@clix.pt :confused:
JB
Re: Mariner 40hp warning sound
Hi, Artur.<br /><br />Welcome to iboats. :) <br /><br />We have a seperate forum for troubles. I will move this to Mercury/Mariner Troubles.<br /><br />Good luck. :)
artur.filipe
Originally posted by JB:<br /> Hi, Artur.<br /><br />Welcome to iboats. :) <br /><br />We have a seperate forum for troubles. I will move this to Mercury/Mariner Troubles.<br /><br />Good luck. :)
artur.filipe
Thanks JB,<br />I only saw I was on the wrong forum after sending it. I posted a new on on the right place, exactly at the same time you kindly moved the first one...<br />Newbie flaws...
