hello i was wondering could anyone help with this headache i have a mariner 60 engine # OP111036 . My system is an ADI with a red stator 3 cylinder with CDM's i have no spark at all 3 cylinders i replaced the trigger box and have done the following test's
Test trigger output spec 0.2-2.0 result=3.8v manuel say's if output is higher than spec test cdm's
done a resistance test on all cdm all passed
test stator output voltage spec 100v-300v result=12v manuel say's if ouput is lower than spec do a resistance test
resistance test on stator pass
I have also noticed that the 2 yellow wires coming from the stator the insulation has melted away and the metal connections were tipping the electrical plate
If anyone has any idea's would be great thank's lad's
