You will require a puller. Ideally one specifically made for the purpose, which threads into the 1-1/2" hole in the center, although you can remove 3 of the center bolts and use a 3-point puller if necessary. Be sure to retorque those bolts to spec after installation.
Do not try to remove it by tapping or prying on it.
