Having intermittent problems with starting the '87 Mariner 60hp 3cyl . Totally cleaned the carbs and know the fuel system is good. Found bad spark on middle cylinder, swapped switch box wires and found a bad coil. <br /><br />After replacing the coil now I have spark on all three but no starting. According to the service manual that I have, I should have 5400 to 6200 ohms between stator windings(red to blue) going to the switch box. I measure only 700 - 800 ohms. All the trigger specs and stator to ground measurements match the manual. <br /><br />My question is does this stator spec sound correct for this motor SN OB158494 and if so do I need to replace the stator? The manual I am using says its good for models before 1986 and my motor is 1987. So I am not sure about the spec. I suspect that the spark that I have is just to weak. I guess it sparks OK out of the motor but not when installed due to compression? <br /><br />Also if it turns out I need a stator, how difficult is it to get at? I know I need to pull the flywheel but what special tools do I need? Or should I take it to a mechanic that has the right tools.<br /><br />Thanks
