mariner 75 no fire on cylinder #1
pumpkin head
Be grateful for any help from any experts out there:<br /><br />Engine: Mariner 75 ELPTO 1995 2 stroke, 3 cylinder<br /><br />I changed the stator since the engine would not start and traced the problem to an open circuit on the low charge coil. Engine ran great for 3 or 4 days......Now i have a problem.<br />The no 1 cylnder is not firing (diagnosed by sequential removal of HT leads. It produces a healthy looking regular spark but the cylinder will not fire. I stripped the carb and cleaned and reassembled but still no improvement(it looked pretty clean). The trigger coil ohm tests looks fine as do the primary and secondary coils. If i am getting a spark could the pack be dodgy or it more likely a fuel problem? Is there an easy test for this?I dont have a peak voltage meter. How can i be sure if its electrical or fuel?<br /><br />Any help greatly appreciated! Thanks
Elmer Fudge
Re: mariner 75 no fire on cylinder #1
Do a compression test on all cylinders and post results.
WillyBWright
Connect an inductive pickup timing light and run it. If the light flashes, the sparkplug is sparking. You can check any cylinder this way. <br /><br />I'm with Elmer on this. I think your problem lies elsewhere.
achris
More fish than mountain goat
Did you swap a known good spark plug into that cylinder and try again? Plugs have been known to fail like this.<br /><br />Chris.........
pumpkin head
Thanks a million chaps. Problem solved. I checked the compression seemed ok(approx 100psi each cylinder). Started the engine on each single cylinder to verify no 1 bad, then swapped around the coils- Number 1 coil would not fire no 2 cylinder. No 2 coil fired no 1. Pretty conclusive. Thanks for all your help. A happy pumpkin head.......
Keith Buchanan
I have exactly the same problem at the moment but I was discounting the coil because of the healthy looking spark I am getting.
