mariner 90hp inline 6
rosser1
well it was turning over, trying to start found fuel leak in fuel line. repalced fuel line, but now just clicking when tryed to start, not turning or any thing, just clicking, is the solinode thing go bad over night
cannonford57
Re: mariner 90hp inline 6
it happens....also check all your connections on the batt.
JB
Battery cables. Remove and clean both ends.
rosser1
would that be at the battery or the solinode, because they are fairly clean at both but i will take the advise and go clean them, thanks i will let you know the out come
ImNu2Boats
Both.. I changed out my starter, got distracted and didn't tighten the negative cable bolt all the way. It worked great that night but the next morning, nothing. Fortunately the suspect was the part last changed and I found he loose bolt right away.
rosser1
yep i found the problem, not really dirty connectors, just the starter cable a bit loose, so i just was wiggling every wire and found it and a few more just a good snug of the wrench anf its all better, still just spitting, not cranking and running. But hey new question maybe yall can help, like i have drained a gallon of gas out and there is a white substaince in the bottom of a clear gallon jug. what is it? and now all the gas must be drained.
rosser1
yep it was water, now with water out of fuel, besides pulling carbs off, can the bowls be drained and pump new fuel in to them, or almost flood the carbs to push out old watery fuel, anything besides having to pull them off and rebuild them.
Chris1956
Rosser, Sidebowl carbs have a brass hex head main jet cover plug. Remove it and pump the primer bulb to expell the water.
rosser1
thank you chris thank you that took a big burden off my chest i didn't want to have to rebuild carbs. i am going to try that i a little while and let you know how it goes.
rosser1
ok, so i did as i was told, i took the brass plugs out of the carb and yes there was some water and milky stuff come out and flushed out the old gas and hopefully all new clean gas is in, still turning over but not hitting. great spark and compression, the only time it acts like it wants to start is when i spray a fuel mix into the spark plug holes. I don't get it i can get lawnmowers, gokarts and tiller going in matter of a day or a few mins. all engines are they same the air and fuel mix and turning over the pistons they will hit or something, but this crazy outboard is driving me bananas!!
Chris1956
You need to be persistant. Pump up the primer until the motor floods a bit, spray the 50::1 fuel mix into the carbs, close the choke shutters and crank it with the cold start lever all the way up. If the rest of the motor is good, it will catch.
rosser1
ok what is the cold start lever? unsure of what or where it would be.
Chris1956
On a standard MerControl the cold start is a lever just above and to the left of the keyswitch. You use your thumb to lift it up for cold starting. Other controls have a throttle only button in the center of the throttle handle. Push it in and push the throttle forward for cold start
