Re: mariner four stroke 115hp
what BillP says,<br /> the filters in the injectors are about 10 micron, the VST and most water seperators about 30 micron, guess where the tiny particles collect.<br /> thats why I reccomend 10 micron filters as long as they can flow at least twice what the engine demands at less than a total of 4"Hg fuel system vacum at the low pressure pump inlet.<br />suzuki came out with EFI in the early 90's, since then merc yamaha and and a few others use the same basic EFI multi port setup. never seen an electrical failure with an injector so far, its always clogged or the pintle is stuck , neither I consider an injector failure.
