Mariner60_hp
- Mar 26, 2003
- 26
60hp 2cyl 1980 Mariner<br />After tunning and piddling with most things on the ingnition and carbs I now have a stable idle, good excelleration and am happy, however I do have a occasional high speed miss. the miss occurs at wot. If I back of the throtle just a tad the miss goes away. I took out the spark plugs that came in the motor and did a cross reference on plus and came up with these plugs plus the factory manual plugs here is what I have discovered so far. This was done before tuning the engine( first thing I did was change the plugs) <br />Factory plug: b8hs .025 to 035 (high speed miss)<br />Autolite plug 4092 .025 to 035 (high speed miss)<br />Champion plug L78 .025 to 035 (high speed miss)<br /><br />The NGK wasn't to bad, the Champion was better and the Autolite was terrible.<br /><br />Now on the front of the carb cover is a large foil sticker that says NGK B8hs-1.0 which is to be gapped at .040, which is what was in the motor when I purchased it. Do you think this could cure the high speed miss?
