Mariner Rebuild cost.
studlymandingo
Much cheaper to do it yourself. More than half the cost. Parts won't be too expensive.
fordv840
Re: Mariner Rebuild cost.
I can't even begin to estimate your costs but I am currently rebuilding a 78 402, 2 cylinder, 2 stroke, and I am into it for about $850. That price is 2 new pistons,rings, bearings, engine wiring harness, and machine work. I figure by the time its all said and done I will be into it for $1000. Yes you can buy one cheaper but I will know whats in this one and a new one is around 5K. I know that four strokes are more expensive to rebuild than two strokes. Good luck,
Texasmark
I had a thermostat lock closed in a '75 70 hp 3 cyl OMC. Required boring and new pistons and all. Had the powerhead done and I did the rest. $1000.
Mark
gungalunge
rebuild it dude . if you want on the lake fast pay the money and be done with it. like some of us out here .take the time do it yourself as fast as you can work hard save a few hundred bucks
funpilot
I just rebuilt a Johnson V-4 Crossflow. New Pistons (and rings), two cylinders honed, two machined, gaskets, carb kits, and sealant for about $650, time elapsed was 30 days.
I knew what the failure mode was, so I was able to reuse bearings, crank was great, and all electrical was fine. I did all the work myself except machining.
When I did my 120 hp Sport Jet boat a few years before, I let the machinist talk me into letting him assemble my engine. I also had a crank which had to be built up and reground. That one was closer to $2500 when I was done, time elapsed was 120 days.
iboats is great for parts, but I would phone them, the website seems incomplete. It also helps to have a NAPA Marine catalog because the part numbers are the same as iboat's.
Good luck!
fp
