MarineTex - FYI
TenE307
i called the company that makes marinetex about a question on curing temp and times.<br /><br />they told me that it will not cure below 50 deg.<br />at 55 it will take over a week.<br />at there optimum 72-78 it takes 24 hours.<br />it does not have to stay the optimum temp for the whole 24 hours. just keep track of time at optimum temp.<br />if outside they said to wrap in saran wrap or tarp to keep the heat in durring the night.<br />you can use a heater they said to keep it at least 4ft away from heat source.<br />they also said that the time to sand is when there is a blemish on top. (in 24 hrs at 72-78)<br /><br />just if anybody had the same questions i did.
crazy charlie
Re: MarineTex - FYI
Simple solution I found years ago was to put a heat lamp (3.99 at wally world) on it and leave it for a few hours.I believe it actually made it cure better.Charlie
Chris1956
Re: MarineTex - FYI
TenE and others. I have used Marine-Tex for many repair projects. I have used it to "saturate" standard fiberglass cloth. This makes it even more resistant to cracking. I have repaired metal fuel tank cracks and auto catalytic converter repairs this way. I also have used a heat lamp on it and it does speed things up. I understand that it is very flammable when soft, so do be careful.
Boomyal
Re: MarineTex - FYI
Chris1956, do you think that marine tex would be suitable to fill small pits in an aluminum gas tank? There are no holes thru the tank.
tmcalavy
Re: MarineTex - FYI
Try to stay within the recommended temp range, or use supplemental heat. I filled a big dent in a gas tank on an old outboard when the temp was below recommended. It hardened okay, but lost little chips off the surface as I was sanding it smooth to paint...so temp affects how it bonds together I guess. Otherwise it is aces.
