Mastercraft Stars and Stripes propeller 4 blade shaft diameter
rob.s.uk
I found a propeller on ebay which is off a Mastercraft Stars and Stripes using a ford 351. Would anybody know the shaft size this propeller fits to. I would think the shaft must be the same in all master crafts but I don't know hence the question.
rallyart
Most Mastercraft props use a keyed shaft and not a splined shaft. That matters if you are putting it on a different brand hull.
