reelfishin
- Mar 19, 2007
- 3,050
I am about to start redoing a transom on a boat in which the inner skin of fiberglass will not survive. On all others I've done so far I've been able to reuse the original inner skin by just re-laminating it back on and fairing it in on the sides, the result has always been a very original look.
On this boat the inner skin is too batterer up to reuse, I will have to replace it. The original skin looks to be just a very thin layer of random direction glass fibers on the wood transom.
I will be using epoxy for the repairs.
My question is, what is the best material to put back? I was thinking just several layers of fiberglass cloth?
I have been getting my fiberglass from a local shop here, mostly I get cut offs of scraps from their manufacturing process. The weight and type of glass varies and there's usually a pretty big assortment. They sell it to me in cardboard barrels, most pieces are far larger than I need for any transom job.
The thickness varies as does the type of fiberglass mat or cloth.
The most common is a fairly heavy woven cloth which most resembles a basket weave or burlap type weave, then the next most common is a straight very thin crisscross lightly woven cloth, much like you get at Walmart in the auto section in those small bags, and then a lot of fairly thick random direction glass 'mat' which has no woven in it at all, its just pressed fibers. I've not used the random direction mat since it don't soak up epoxy well without a lot of thinning, I've been using the woven cloth in between all layers in the transom, and using the thinner cloth and some thinner mat for fairing the edges.
On this boat, the transom inner skin is so thin it all but fell apart when the wood rotted, it broke up like dry paper.
If I want it to match the rest of the boat, I'd have to use the random mat and do some additional glassing around the edges. The original transom's inner skin isn't very well attached to the boats sides, the layer of glass isn't much thicker than a good coat of paint. The motor on this boat will be an older clamp on Mercury with only two lower bolts, so I will also be adding an aluminum clamping plate to protect the fiberglass up top.
Which type of glass should I use for the inner skin?
