minuteman62-64
- Apr 12, 2011
- 1,350
As part of the renovation work on my 1982 Bayrunner, I will be adding a platform in the bow - between the bow and the front bench seat, with storage under.
The original construction of the Bayrunner has the plywood components mounted to the aluminum hull with aluminum "L" brackets formed from 16 gauge aluminum. I plan to follow the original constuction by mounting my platform on "L" brackets, pop rivited (closed end pop rivits) to the aluminum hull in the bow section.
My questions are:
1. For 16 guage aluminum "L" brackets, do I need to use a marine grade aluminum? Or will any 16 guage aluminum sheet material suffice? I don't know if the existing interior aluminum fixtures are marine grade or not.
2. Are pop rivits available in a marine grade aluminum? Or, is that not an issue?
3. Should I use stainless steel (or other material - monel??) pop rivits as an alternative. Because of the size and configuration of the platform, structural strength will not be a huge issue.
Any and all input appreciated.
My questions are:
