cprince
- May 22, 2008
- 148
I have a line on two motor halves. I know little about Johnny-Rudes...
Here is the add for the top end;
1974 Johnson 20 hp Outboard
In good condition but needs the bottom end. Compression very good. Excellent part motor or whoever wants to repair it. Everything else is complete.
$150
I asked him for some detail and he e-mailed me this;
"Serial number is C13000, the bottom part which includes the prop. Everything appears to be there. Compression is over 85 lbs per cylinder."
And for the bottom end:
Evinrude Johnson 18-25HP lower unit gears, etc. - $100
Lower unit gears, shafts, bearings, etc. for 60's - 70's 18-25HP outboards.
So... the way I see it, I should be able to get a 20hp Johnson motor for around $200 (I am quite good at haggling!)
What do I need to watch out for... should these units be compatible? What do I need to make this happen? I would imagine that there are gaskets involved... gear oil and the like...
Any suggestions? I have worked on cars all my life... but not OBs.
Thank you all!
$150
Thank you all!
