Re: Max swells for 20' cuddy?
Yeah, I was thinking of more gentle, ocean swells, without the wind.
Assuming no wind condition, it's wave period + height which are your considerations. Plus, hull length and boat speed. At a certain speed you wouldn't have a problem in swells of even 40' or larger. Really.
In larger swells you may feel a pressure change and the boat may react to that airflow (ie, wind) cause by that pressure difference 'tween trough and peak. Still, it would be nominal until the winds kick up.
I would take a 20' cuddy into 20' and larger. Wait...I have, over inshore shallows too.
Wind plus swells is much worse, the swells get much steeper.
Yes, it is the seas which can cause problems. Even if they are short and choppy, you may have varying winds (speed and direction, ie gusts) which make handling more difficult. With a current set opposing the winds then you may have difficulties in maneuvering.
Again, it's speed which is your best tool. Jocky the throttle as required and in conjunction with steering. If it got really bad, you throw out a drougue and heave. Or maintain minimal steering speed.
EDIT: in short and choppy, pick your course. It's gonna' be a cork screw. Depending on wave ht and swell patterns, try to find the best course to ride the backs of the dominant swell and get into port or stand off from the area causing the chop. Bottom contours factor greatly here. Usually there is a current setting up the short chop.
Once while out on Lake Powell a storm blew up. The winds were fierce out of the NE but the prevailing winds had been out of the SW. Running before the storm we ran smack into the 4-6 waves set by the prevailing winds. I chose a heading off to the N while other boats went direct to the marina. I ran about twice the distance over ground and still beat them back to the marina. This because I was able to put the waves to athawrt which made for a smoother and faster ride. Don't fixate on a straight line navigation in those conditions.
Willard Bascom's book,
Waves and Beaches is a good read. I think it's out of print and it's not about boats per se but it is a good reference for understanding swell patterns.
