bryanwess2000
- Jul 16, 2008
- 240
I finally ready to time my motor. Idle stabilizer has been removed and I want
to set timing safely. The manual and flywheel cover says 19* at cranking
speed which is 17* above 5000rpm so I'm guessing the ide stabilizer retards
timing above 5000rpm. The manual does not mention this only timing advance
at idle when shifting into gear.
So what is safe timing on todays gas without an idle stabilizer. I"ve seen
posts on S&F forum where people are running 25-26*. I'm not that brave.
