500dollar744ti
- Jul 23, 2012
- 691
I have a set of the mercruiser silent choice exhaust cutouts that I want to install. My boat has an integrated swim platform that is exactly at the same height as the current exhaust riser outlet.
Can I space the riser up another 4-6 inches so I can install the thru hull exhaust above my swim platform where I can cut holes without having to go through the thick wood of the transom?
My engine compartment is crowded as it is and putting the thru hull exhaust below the swim platform would require both cutting through the transom and rerouting a lot of wiring and hydraulics for the trim tabs.
I am asking is there a maximum height for the exhaust riser above the manifold? I tried searching for mercruiser engines with something like 8 inches worth of exhaust riser and couldn't really find anything.
In theory how high could you possibly have a riser before it becomes a problem, if it can become a problem?
