mc-1 gimbal bearing and shift cable
harman79
Can I use a alpha bearing to replace the snap ring bearing that I have.
I also need a new shift cable and they don't sell one that bolts in from the front. Can I use a alpha cable the bolts in from the aft. Are the lengths the same or don't matter. one last question Does anyone know what would cause the upper unit to rub hard on one side of the gimbal ring.
Bt Doctur
Re: mc-1 gimbal bearing and shift cable
using the new type of bearing is fine, same for the shift cable. you do need the special tap .no cutting necessary
achris
More fish than mountain goat
.... one last question Does anyone know what would cause the upper unit to rub hard on one side of the gimbal ring.
Post photos... but if you're talking about the bottom part of the gimbal ring (the drive side supports) that's normal...
harman79
Here is a pic off the wear. Also are the bellows for a alpha smooth where they clamp on or is there a ridge?001.JPG
achris
Here is a pic off the wear. Also are the bellows for a alpha smooth where they clamp on or is there a ridge?View attachment 152095
WOW!!! That's one very old unit... I can't help you I'm afraid, I've never worked on anything that old... Sorry...
old style shift cable is available here at iboat store Part # 18-2248
harman79
are sierra a good cable? It also says it does not have the support tube. What is that?
Bt Doctur
go with the newer style cable,the thin tube that went over your thin cable was called the suppport tube. new cable eliminates it and the cutting and measuring.
