L8-Again
- May 8, 2010
- 55
My neighbor knows I have done LOTS of my own repairs.....but I am NO expert and the only reason my old boat is running as well as it does is because of the information I have found on this site.
At the lake a few weeks ago his engine quit hard while accelerating. Engine would not crank. Removed drive, engine cranks. Pulled drive cap and saw a couple of broken teeth. Oil drained out clean, no metal or water, upper seized.
His is a 1985 Alpha and I have a 1979 MC-1, same gear ratio numbers stamped in the uppers, 1.65, both v-8 chevy powered 260's. His actually may be an R or MR but I did not check the serial numbers. I will call it an Alpha for now.
I was thinking about selling my extra upper to him (cheap) but I am wondering if it will actually work. When I replaced my outdrive I used SEI upper and lower complete even though the upper was just fine. The lower was damaged in the driveway by the previous owner, forgot to raise it to move the trailer.
I can see a few obvious differences in the two: cap has lifting hole, ribs on the side, the anti-cavitation plate is much smaller on the MC-1, smaller rear trim cylinder mounts--less metal but same sized hole; but there may be other differences I cannot see or do not know about.
I was thinking that there might be a problem with the Alpha lower main shaft not having a grove below the splines for an o-ring or the pre-load pin in the end of the shaft. Haven't split the Alpha apart yet.
Basically, if it works then we can put it back together tomorrow and be on the lake. If it doesn't, then I'll have him order an SEI and we can bolt it up and go to the lake in a week or so!
Has anyone successfully done a 'marriage' like this and been successful?
L8-Again
L8-Again
