McCulloch 7 1/2
McCulloch 7 1/2
I just got a McCulloch 7 1/2 hp motor form my grandfather im not sure of the year but it must have been made before the scott merge ... im trying to find blueprints of the motor or somthing along the lines of a motor guide , so far i have free'd the motor and cleaned the points it has spark like it was made yesterday and it only looks a year old , if anyone can help with a good link ECT , it would help , thank you <br /><br /> your newbie , McCulloch
alcan
Re: McCulloch 7 1/2
Hello McCulloch<br /> I had a couple of those motors a few years back. I belive I found the imfo I needed at the public library. This was prior to internet. I have seen sites on the net. We will have to have some one else tell how to get there.
Franki
Re: McCulloch 7 1/2
I don't know of your outboard specifically, but as I understand it, McCulloch stopped making outboats in 1968... you might try looking around at: http://www.vintageoutboard.com/ they might have what you need.<br /><br />Doing a search, I found this.. but its a google cached page and may be gone now..<br /><br /> http://216.239.51.100/search?q=cach...speedbot/McCullo.htm+McCulloch+outboard&hl=en <br /><br />it might be worth a look though. (you'll have to cut and paste that url into a browser bit by bit)<br /><br />rgds<br /><br />Frank
McCulloch 7 1/2
Re: McCulloch 7 1/2
TY you , i have spark and fuel but it just wont start , i have good compression , all seems to be in order ... but no start ? any ideas at all , here another thing , if i pull a sparkplug out and ground it it will make flame but not woth it in , any ideas ?
alcan
Re: McCulloch 7 1/2
Hi McMulloch<br />These are just some ideas. You said you freed the motor. Are you sure you have compression? Did you use a gauge to test? When you cleaned the points did you get the fly wheel keyed to the crankshaft properly? You said you have fuel. Do you have fuel in the cylenders? Are the spark plugs wet? Did you clean up the carb? Are the needle valves set correctly? As I recall those motors use a unique carb system. Do you have the spark wires crossed. Is the point gap set right?<br />I'll guess and say .020? If we have compression in the combustion chamber, air\fuel\oil and spark at the right time, it will at least pop. Well keep working on it, I have a feeling it's a simple little thing. let us know how you make out.
McCulloch 7 1/2
Re: McCulloch 7 1/2
yeah i work on it a little everyday , today im about to check on the carb , even when i spray ether in the chamber i get no pop ..... is there a chance that my coils are weak and it cant fire under compression ???? im gonna get new sparkplugs...
alcan
Re: McCulloch 7 1/2
Hi McCulloch<br />I think just about anything is possiable. Unless you can see a problem with your coils,(cracks, arcing to the stator plate,etc) odds are thier ok. Since you have spark, I would look at plugs. Were you able to come up with specs for that motor? Please don't use any more of that ether. There is no oil in it, it's not good for your motor. Or any other motor, in my opinion. To test, or prime, just squirt a little pre-mix in it. gasoline is violot stuff. If you got fire, it's going to burn.
smee
Re: McCulloch 7 1/2
I just picked up one of these motors and was able to find some info at the library. Glenn's Marine Series, Sears Outboard Motor Guide, appears to be the same motor I have which is a 63 Scott McCulloch 7.5 fishing motor. The guide is a complete repair manual for this Scott and a few with less and more hp. <br /><br />As far it not starting have you opened the vent on the fuel tank? If you don't open this and it does start on choke you may damage your fuel pump. Don't worry. I know a fellow that can order a snow machine fuel pump for about 30 Canadian that replaces the original. Anyway hope this works. Get back to me if it does.
rickdb1boat
Re: McCulloch 7 1/2
Try putting a spoonful or two of premix directly into the spark plug holes into the cylinder and see if it pops. Put some new plugs in before you try it again.
alcan
Re: McCulloch 7 1/2
This post is almost a year old. Dated april-02
