San_Diego_SeaRay
- Nov 9, 2014
- 343
Engine: 1981 Mercruiser MCM 260 retrofitted w. the MCM 260R Center Rise Manifolds and newer thermostat housing
I'm rebuilding this engine, on the verge of getting it started (may get it started tomorrow) and I plugged a hose into the intake port on the t-stat housing. Water started coming out of the side of the Chevy 350 through a threaded hole mid-length along the block right above the oil pan. On the direct opposite side (starboard) of that threaded hole, there's a little spigot thingy that I guess is a drain ****. Also, water started coming out of a little hole right at the base of the final manifold exhaust outlet, where the "boots" mate w. the riser. I've included a picture pointing to the hole, and another picture showing the hole location better (although you can barely see the hole).
3 questions if I could:
Thanks in advance!
- JC
- On initial start up after a long rebuild and my water jacket is dry, if my thermostat is not open and water is being re-directed to the risers and bypassing filling up the jacket, isn't this going to be a problem? Seems like the engine will be running for a while w/o water to help absorb and dissipate heat.
- The port side hole probably gets another drain **** just like the starboard side, right? Can I just put a bolt in there w. sealant if I never plan on winterizing the boat?
- What's the little hole in the riser for? Water is only leaking out of the port side. The starboard side has a hole there too, but it looks like it might be plugged.
Thanks in advance!
- JC
