MCM260 5.7L rust on spark plug
tfret
While changing my spark plugs this weekend I noticed that I have rust on my no.5 plug. Not a lot of rust, but rust none the less. What does this mean?
TilliamWe
Banned
Re: MCM260 5.7L rust on spark plug
It means you are getting water into that cylinder. THAT probably means you have an exhaust system issue. Good luck.
Ayuh,... My 1st WaGuess is the riser/ manifold joint/ gasket is failing,...
Especially if ya boat in the Brine....
tfret
The boat has only been in fresh lake water. Do I need to pull the riser and exhaust manifold to inspect? I really need some guidence here. I don't fully understand how the water and exhaust combine, I've never taken it apart before. I just need to know how it works and where to start looking for problems. Thanks!
tfret
After spending some time searching this forum i've gotten quite an education. Seems that the riser to manifold gasket could be leaking into the exhaust chamber and running down to the engine block. That is easy enough to pull and replace. Would it be wise to pull the manifold to inspect it too, or is manifold failure far less likely in fresh water.
wire2
I expect you're talking about rust on the part of the plug inside the combustion chamber, not on the outside shell, correct?
tfret
Yes, the rust is on the "rim" of the plug opposite the end where the wire connects. The rim seats against the head when screwed into the hole. Indicating water getting into the cylinder. The compression is tight on cylinders so I don't expect a head gasket.
