Me again another what is this boat LOL
Airwolf9090
I been trying to guess this boat. My buddy gave it to me and i was only there long enough to get photos, i would of brought it home but its tandon Axle trailer has trailer breaks and the breaks are locked up.... Anyone care to take a guess? I was thinking a cobalt Tri-hull.. It has a Ford 302 V8 I/O
roscoe
Re: Me again another what is this boat LOL
Got paperwork?
Look for the hull id and post it.
Airwolf9090
no paper work yet. Like i said all i had time for was them few photos.. Being in a hurry sucks and its 150miles away at my buddies shop in the middle of nowhere called Hawkinsville near Warner Robins, Macon, Cordele, etc while i am Savannah lol planning on going to get it some time this week or next. but was hoping someone might have a idea... Heck anyone ever delt with locked trailer breaks?
skyaggie
The easy solution is the wrong settings on the trailer brake controller.
If not, Some trailers are equipt with an emergency breakaway brake lockup. Check for this make sure the emergency trailer brake has not been engaged
veritas honus
My trailer has surge brakes. There is an emergency brake cable which I connect to the hitch, along with the safety chains, which are a few inches longer than the cable. If the trailer breaks away, the cable tightens and engages the brakes (before it also breaks). This will help prevent the trailer from slamming into my truck as I slow down with the partially detatched trailer. Check to see if you have this feature. If so, spray liberally with WD40 and make sure that the mechanism is not engaged. If this is done, and the brakes are still locked up, you'll probably have to deal with the problem at the source... the brake, or brakes themselves. It may be as simple as freeing the brakes with WD40 and some manual labor. The brakes may also be so rusted/coroded, that they're fused and will not release with an application of WD40. It may require you to remove and replace the brake/brakes.
The boat does not look to be too big to transport without the use of trailer brakes, as long as the trailer is otherwise completely servicable and safety chains are not rusted. If the safety chains are rusted, please replace them prior to transport. This is also contingent upon whether or not your tow vehicle is sufficient. My tow vehicle is certainly capable of towing my trailer and boat without the brakes; regardless, if my trailer brake were to become inopperative, I would alter my speed accordingly for the safety of myself and others.
She's a good looking boat. With lots of TLC and a probably just as much money as TLC, you should have yourself a beautiful rig.
Best of luck to you. Please keep us posted; and we'll be looking forward to the upcoming thread you'll start in the restoration forum...;)
...And welcome aboard!!!:D
Airwolf9090
I am not too worried about towing i pulled heavier things. I use my 96 ZJ 5.2L AWD. I am just worried about getting the breaks free to tow it. I don't need the breaks working to tow the thing I just need it rolling. But my buddy even tried dragging it to free up the breaks. I don't him it wouldn't work that way lol
Airwolf9090
Breaks were not a problem they were good.. Turned out they didn't know how to work the breaks right. Here is some photos after alittle cleaning and still alot of cleaning to do. Anyone in the Savannah area know a good source for marine plywood? Or should i just use treated plywood? The battery was still good even after it sat all these years.... I am getting power gauges come to life blower works but no lights and the outdrive is not going up or down. And i have yet to start it or turn it over.
Uploaded with ImageShack.us
Summer Fun
Banned
They're called ... Brakes not Breaks. :facepalm: . :D
All kidding aside .. nice score on the freebie.
Clean that puppy up and go boating and be safe out there. :)
90stingray
That looks like a ton of work... good luck bro.
Airwolf9090
Not really alot of work. Just a floor, and looks like a starter and the electric motor for the out-drive tilt, plugs, plug wires, oil change. everything else is working
zopperman
and probably stringers and transom.
^^ That.
Also, no treated wood, no MG... any exterior grade fir will do.. I use ACX arauco from Lowes. none of my 3 sheets had any voids...
oops!
bud.....dont spend a dime on it till you get that motor going and the drive working.
the words 'just a floor" and "stringers" are a lot bigger words than you think
zopperman
correct me if i'm wrong, but that looks like an OMC drive...?
oops!
yep....it is......comments witheld
oops!
same thing that patrick is doing the conversion from.......possibly he will have parts for the op
oops!
Frank Acampora‎ might have parts as well
zopperman
:facepalm:
but go me for learning about I/os!! :D
kahuna123
Its looks like a Crestliner. Do yourself a favor. Save the thousand hours of hard work, 3 grand of hard earned money and buy a nice used boat. The market down here is great.
