jasoutside
- Dec 20, 2009
- 13,269
Me vs. Propane Guy
So I am always trying to figure out how to win against the LP guy. Over the last couple of months I have kinda, sorta on purpose let my 500 gallon tank run out. I had already decided to swap out a couple of my appliances so the timing was fine to do so. I was so excited to see that big pig hauled away
I called a new LP company and got a better deal on LP at $2.40/gallon, free set up and LP delivery, $12/year tank rental. Better than what I was paying. The only thing I'll have on LP from here on is kitchen stove and back up furnace as I heat 100% with wood.
I currently have a nice big 80 gallon LP water heater with power vent. With what I was paying in LP to run it I'm guesstimating that it was costing me in the $650ish/year range, give or take. I figured I'd spend that, or maybe less on an electric water heater.
I was just getting ready to grab the good old fashioned stand by run-of-the-mill water heater when this fancy pants thing caught my eye and I started doing some research...
http://www.geappliances.com/heat-pump-hot-water-heater/
http://www.youtube.com/watch?v=ut2l...y_mode=true&persist_safety_mode=1&safe=active
It was $1600 on sale $999. 1000 bux, ridiculous right? Well I did some math...
$1000
-$300 tax credit from the gubment
-$75 credit from local utility
-$300 after I sell my perfectly good LP 80 gallon water heater
=$325 which was what I was going to spend on a new electric water heater anyway. With the energy saving numbers they are touting I'd recoup that after year one too. Even if the thing poops out on year 10 I figure I should save $3000ish (maybe more) over that time vs. a regular electric water heater.
Couple of other advantages I am thinking...
-Since I heat with wood the basement is hot 8 months out of the year (wood burning furnace is in the basement). This thing uses ambient air to heat the water and the hotter the air the more efficient the water heater is (as I understand it). That said, my savings might be even a little better.
-My dehumidifier bit the dist this summer (it's like 25 years old) so I needed to grab a new one. Those things are expensive at $200ish. This water heater basically has one built in to take humidity out of the air. So now, I don't have to buy a dehumidifier, that's good.
Couple of things I am a little concerned about...
-I just hope the savings calculations are true. Based on what I have been reading, I think so, could be wrong.
-Little concerned with the new technology. $$$ if it breaks. It does come with 1 year parts/labor, 10 year parts so that helps the cause.
Anyway, long winded sorry...
I know some of you guys around here are into energy on the cheap when you can find it so I thought I'd post up if you are in the market.
Anybody out there use one of these things? Good? Bad? Terrible? Great? $$ savings? Not so much?
I'll post back my findings in 2021
$1000
