Measuring 3 Cyl Engine dwell.
mscher
I have a dwell meter (very old one), but it only measures 4, 6 and 8 cyls.
For 4 cylinders, it says to double the 8 cyl dwell reading.
Would this work for a 3 cyl, to double the 6 cyl readings.?
Is there another way?
j_martin
Re: Measuring 3 Cyl Engine dwell.
Yup.
Dwell is a measure of on vs off time based on the total number of degrees devoted to one cylinder. Thus a v8 4 cycle engine has 90 degrees per cylinder. 50% on (normal points) would be 45 degrees. 6 cylinder is 120/60. 3 would be 240/120 8 cylinder 2 cycle would be 45/22.5
62 ROYAL SCOTT
Hell-o what great info we get here at iboat thanks iboat members
