Measuring steering cables
DocBob
I need to replace the steering on my bass boat, and a friend just replaced his with hydraulic (I would love to do that too but don't have the money).<br />He pulled the "old" steering system out and said "Here, if you can use it it's your's. I measured my boat (center of steeing wheel, around the hull to the center of the motor and come up with 10 foot 5 inches, rounded up gives me 11' system.<br />I don't know where exactly to measure the steering system my friend gave me. When I lay it on the boat is appears to be less than a foot "oversized" so I think it's the right one. It measures 11' from the center of the steering column to the start of the threaded portion of the motor connection. Does it sound like I got lucky enough to get the right one???<br />Thanks,<br />Bob
Re: Measuring steering cables
It Sure Sounds like the 1 you're looking for.......<br />Usually, the length of the cable is printed on the outer sheath, about 2/3s or 3/4s the way from the helm..........<br />Good Luck...
DocBob
Thanks Bondo, I did look at the printing on the cables, but I really can't read it very well. I think it says 12' but I'm not sure.<br /><br />I guess my question is, if I pull the old steering off my boat and it does turn out to be a foot shorter than the new one, can I still use it? I'm sure there's enough room along the sidewall of the boat to just put a "lazy-S" in the cable and make it fit. Is there anything wrong with doing that?
Should work just Fine.......
