mech fuel pump removal
rock10
recently purchased 89 cobia with the 2.3 liter ford engine,the boat has electric fuel pump,my question is should i remove the mech pump and block off or just leave in on,thanks
Re: mech fuel pump removal
Ayuh,... Got a Picture,..?? Is the electric pump wired through a safety switch,..??
rock10
not yet but it will be,per previous post,its wired to the access toggle switch on the dash,gonna order one soon
rock10
thank you mr bond-o the electric pump on the boat is a facet posi-flo efp-3 and i was told that it is not marine rated but on there website is says for marine use from the best i can read maybe im wrong can you tell sir about this pump thanks much appreciated
bomar76
When I looked I could find no US Coast Guard approval for that paticular pump...if you found one for that model I stand corrected.
None the less, it is wired in and unsafe manner and needs to go through an oil pressure swith per our prior discussion.
If you keep an electric pump I advise removing the dead mechanical unit and fabricating a block off plate.
rock10
thanks bomar iwill do that and find differant pump,i was thinking that the rocker arm in the mech might chip break lose and do some damage
rock10
so i assume i cant buy a block off plate not to good at fabricating any other suggestion? thanks
Ayuh,... I'd leave well enough,........ Alone.....
rock10
coming from you mr bond-0 iassume the dead pump will not hurt anything thanks for you help
