Hello. New member but have been researching on Iboats for a couple of weeks. I bought a boat a month ago that has a Mercury 850 outboard. It is the blue line with the thunderbolt ignition. The seller advertised it as a 1985 motor. My research showed this was a mid 70's motor. However, the data tag on the swivel was for a mariner 90hp inline 6. Serial #A117802. This would lead me to believe the 850 and swivel met up later in life.
I have not been able to located any other serial number on the motor itself. Currently, I'm trying to identify the motor so I can order the manuals etc.
When I checked out the boat the guy ran the boat and it idled fine. He put it in and out of gear a couple of times. I had a boat shop do a compression check, which I was not present at, it ran fine then. After a couple of weeks I started it up to run the gas out. I runs great at 1000 rpm but will not run in neutral. Am I missing something simple?
I attached a side pic of the motor.
Thank for the help.
Thank for the help.
