OK I have never seen this happen I need help. <br /><br />I have a 1993 Mercruiser 5.0 LX engine in my Larson Bow rider. Today I got in the boat and turned the ignition over. The started turned but did not engage. I tried a second time and everything worked fine. I docked at the fill station and filled her up with fuel. When I restarted her the same thing happend on the first attempt. The second attempt the starter engaged but did not have enough juice to turn the engine over. I switched the ignition to off but the started kept cranking. After fooling with the switch for about 20 seconds I pulled the safety lanyard and it shut the starter down. When I opened the hatch I saw smoke coming from the battery box. I got the fire extinguisher and opened the battery box. <br /><br />Inside I found that the terminal with the positve lead connecting to the starter had melted through the top of the battery and into the acid. I got the battery off the boat and on the dock as fast as I could. <br /><br />Has anyone seen this happen before? Did something in the starter short out and draw to much current? Why didn't the ignition switch shut the starter off, but the safety switch did? I assume the starter is bad, and the battery deffinately needs to be replaced, but is there anouther problem elswere I need to look for? I am having the marina diagnose the electrical system before I replace any parts, but I want to make sure nothing is overlooked. <br /><br />Thanks for any help you can provide.
