bought a boat 89 cajun with a 175 hp johnson gt about a year ago or so---the boat had a cylinder down that was repaired with a piston& rings on only that cylinder--- boat runs fine--- compression on all cyls right at 100 cold---question i know the horn is bad but should i have a volt spike to horn when key is first turned on--- disconnected horn and hooked up dvm to horn leads--12vdc constant---started isolation at temp sensors in heads--moved to vro pump connector--then to float in tank ---still with 12 vdc at horn connection switch on--i know some of this safety runs thru the power pack but it is new to the engine---the horn melt down could have occured when engine went down but i dont understand why i cant isolate the voltage to horn--i must be missing something here-- thats why i ask the experts
