Merc 1 prop shaft seal removal??
tcooke
I have a 1967 Merc 1 outdrive for my 110Hp Mercruiser. I have removed the prop and am left scratching my head as to how to remove the prop shaft oil seal. It is pressed in there pretty good.
Thanks
Bt Doctur
Re: Merc 1 prop shaft seal removal??
Actually, theres 2 in there.back to back.Best way is to pull the carrier.
tcooke
I figured as much as my seal kit had 2 of them. It looks as though there is an outer ring that needs to be removed using a spanner wrench then the carrier will come out. Is this right? I tried reading through my manual but it doesn't have very good instructions....
Is there another way of removing the ring without a spanner wrench? (I know about bending the tabs first)
