Merc 1 vs Alpha 1 props.
Boomyal
are they interchangable? Pitch and diameter not withstanding. I speaking of the hub particulars.
walleyehed
Re: Merc 1 vs Alpha 1 props.
Not sure what you're getting at...The merc/alpha is the same thing really...
This is a c&p of My response to the Same Question Boomyal posted over at the I/O forum......
Bond-o said:
Are there any Merc I/O props that are not interchangeable, pitch and diameter not withstanding?
The Propshaft, Splines, Diameter,+ Length are the Same for the Large Gearcase Merc. Outboards, The Alpha series from Begining to End,+ the Bravo 1s........
Besides Blade Design,+ Pitch, Etc...... They'll All Interchange..........
And,....
A prop for a 4" Gearcase Outboard can "Get you Home",....
But the Gap around the gearcase causes it to Blow-out at much more than Idle.......:love:
The 1s that Won't interchange would be the Bravo IIs,+ IIIs, the TRSs,+ TRs, and the Little outboards......
Probably the Fancy Merc. Racing Products Too,.... Black Hawks, etc.....
thdog1
is the nut holding the prop on the drive the same on alphas and bravos?
thanks thdog
