Merc 115 four stroke engine removal
Ricktrevi
2004 merc 115 four stroke engine ..
Could someone tell me how can I remove the engine from the lower unit, or oil pump, Not sure..
I know it has 3 bolts on each side and two more in the front but no matter what I do I can't get it to separate so I can remove the crankshaft cover..
I need to put new inserts cut the crank.. Also change the seals..
Thanks for the help, if I need to post pictures or if you can send me pictures I will appreciated a lot
Ricktrevi
Thank you for your replay, I have already removed the six bolts, three on each side.. My questions is, do I have to remove the exhaust cover before I can remove the engine?
Not sure ..
Thanks
GA_Boater
I can only suggest reading and following the instructions in the link.
