Merc 115 ,how old & cooling system
allday
I'm looking at buying a boat with a Mercury 1150 115 hp motor. I started motor twice for 5 to 8 seconds each time before taking it to the lake. We set motor into water but no water was being 'pissed' out. I immediately shut off. Lady said she thought it had to run awhile. Restarted. I was in boat & the lady & a friend of mine both said water was being pissed out. After I took home and put ears on & ran water nothing was being p'd out.Do I have to run awhile to open thermostat? Does this motor have a thermostat? I ordered a impeller cuz I read on forum it should be replaced regularly anyhow.The motor serial # is 3026571. I haven't a clue as to what year it is. Mid 60's to early 70's some one guessed. I've been told motor is probably worth $800. to $1,000. Any ideas out there? This is my first boat,and I know very little ('very' little!!) about boats. <br />Any help and/or info would be more than appreciated! <br />The seller said the boat was last out two summers ago.And I live in south central Wisconsin. Motor fired right up all 4 times. She wants $700. for motor,'73 Glastron (which seems to be in great physical condition) and trailer(not the greatest but will do the job locally)<br />Many 'THANKS' to any one who replies!!!The lady at the marina wasn't too helpful.She said they'd have to look at it in the service department and they're busy for the next two weeks or so!! Thanks! Allday
hondon
Re: Merc 115 ,how old & cooling system
Yes it takes a little while for these old girls to start peeing and even when they do it can be a little pathetic at idle .If the lady does not know when the w.p. impeller was last changed then I would certainly change it.
kevlar3000
Your merc is probabley between 71 and 77 depending on the serial # and the cowel colors. The 1150 is definately a 70s motor. I had one and it did not take too long for water to come out, so get that checked out. What model glastron? I have a 74 CV16. You should check out boatclassics.com and register your new glastron....<br /><br />Enjoy!!
Bear
1150 (115,0) 3023086 - 3270479 1971 6 cyl inline <br />It is a 1971<br />/Bear
TONY H
I had the 140hp inline 6. It might take the better side of 8 seconds for it to pee out.<br /><br />Sometimes a little bit of crud gets hung up in the 'pee' line. start it up and blow back into that pee hole, it may clear out.<br /><br />It is good insurance to replace the impeller.
news.kraits.org and the newsgroup is: bigweek.mercury-inlines <br /><br />This is a news group for inlines. It is very informatitive.
mellowyellow
'70 merc 1150, pees pretty quickly on the muffs<br />but could be low water pressure on your hose. little critters like to make homes in peehole, so blow it out with air.
Bear
"posted July 07, 2001 10:56 AM<br />I'm looking at buying a boat with a Mercury 1150 ..."<br />A litte late DrippingWithGold. Don't dig up old posts. It will fool others to reply. :mad: <br />Start a new topic instead.
