onthenomini
- Jul 10, 2004
- 2
I have a beep beep alarm even with the engine not running and oil reservoir full. I disconnected the blue bullet wires located under the starter (from the low oil sensor?) and the alarm stops. Does this mean the sensor in the oil reservoir is bad? If this is the problem can I take the oil reservoir off and replace the sensor or is it built into the tank requiring replacing entire oil reservoir? Thanks very much for a response.
