merc. 140 inline, idle's at 2500-3500 rpm's????
toocanshan
i need help i had just bought this boat yesterday and i tried to run it today and the rpm's are of the charts. this morning i put a new impellar in and then i took it to the lake and i can't get the rpm's to drop. i did not even try to run it becouse i was affraid to drop it into gear at those revs. if anyone can help me that would be great. thanks toocan. im not new but returning from the past, with my new 1978 glastron 16' with the inline.
madgadget
Re: merc. 140 inline, idle's at 2500-3500 rpm's????
Id check that the throttle is closing fully and that the throttle butterflies are also closing as they should be...
Fuzzytbay
Is the fast idle lever on? Year/serial number might be of help too.
Check your butterflies in the carbs. See if they move.Its either the idle is set to high, the cable is missadjusted, or not connected at all. The control box is out of adjustment, or the cable/control box is NFG.
toocanshan
thanks guys ill check those things in the morning. the serial # is 4866506 and the model # is 8526622. thanks for all your help and info.
Chris1956
Remove the wrap cowling and see if the throttle is pushed closed by the throttle cable. The throttle should be completely up against the stop, when the handle is in neutral and the cold start lever is down. If not, remove the barrel nut from the clamp and adjust it to push the throttle closed.
