Re: Merc 140 Problems
Fish, sometimes how a question is worded can lead to different answers. The above advice is excellent. Just to make sure we all understand what exactly is happening with your boat : 1) When you say that it will not start without adding gas or starter fluid.....are you aware that most boats with carbs require you to "pump the throttle" a time or two, then set the throttle a bit above idle before cranking (very different from a modern car)? Your question about the prop "clicking" when giving it gas.....is this in the driveway, out of the water ? In neutral or in gear ? If in the driveway, in gear, is this WHEN you give it gas...or when you LET OFF the gas ? For instance, if you rev up a boat, out of the water in gear, as soon as you let off of the gas the prop is still spinning faster than the drive gears....it will click....that is normal. Just trying to get a clear picture of what is happening.
