swihartart
- May 4, 2009
- 82
1977 Starcraft I/O. Tri-Hull 140 Merc.
I am trying to fix up my new old boat. After having it out for the second time, hit a sand bar. A small hole in my trim cylinder appeared. I decided to work on the trim system since the rams looked old and pitted to begin with as well as the lines looked old (cloth style). Rams were patched many times.
I replaced the bottom assembly of the Prestolite Pump. It just screwed right to the bottom of my reservoir around the perimeter. (6 or 8 screws) Mine blew one of those small o-rings on bottom of "dog bone" just after the port cylinder started leaking where it was patched.
Also bought 2 "working trim rams" fom Mike's Alphas on Ebay. They appear to be in good shape. He also sent 4 stainless lines for outside and a distribution block.
Bought 2 new lines. Black for up side of pump. Grey goes from reverse lock to block.
After installing everything, here is my problem.
Port side ram will go down but not up.????? It will move slightly but then stops. Coming back down no problem.
Starboard side: Up goes slow, pump sounds strained. Down no problem.
I took one of the old rams that was not leaking and swapped out the starboard ram and it does the same thing.
I bled the system several times while keeping it topped off with the rams in.
Trim Rams are not connected to back pin during this problem. Been reading. Could a trim limit switch be the problem????? Manual says to disconnect rams to perform bleed procedure.
Ant ideas are greatly appreciated.
