SSTKO81
- Jun 1, 2009
- 347
Where to start???? Ok so when launching off the trailer, she started almost right away. I let her warm to just over 100* (according to the thermometer on the dash) at around 700 rpm or so; then went to put it in gear. I've always been told, dont do it slow, just pull it back till you feel it kick in. -so i did, and it died. and it died and it died. After 4-5 tries I goosed the throttle to 1500 RPM and jerked it quick into reverse. It tried to die but recovered and I got off the trailer put it in neutral and all's well. Then I shifted to drive and died. and died and died. Again after 4-5 tries I goosed the throttle up to 1500 RPM or so and dumped it quick into Drive (yes, i know... shouldn't do that) but it stayed running. I idled out of the cove at 1000 rmp or so and finally gave it gas. -got up on plane and ran great at WOT 4200 RPM. Reached a fishing spot and slowed to idle and it died. This time it was VERY difficult to start, taking 8 tries or more and when it did, absolutely would not go into drive. -it would go in reverse though. So i had to back up about a mile to the dock. I never could get it to move in drive. It died every time. I was told it may be a fuel issue? I was also told it may be a shift cut-out issue? Ever seen this before?
