merc 150 black max v6
jiml100
bought a boat with bad motor. oil injection line was replace put on wrong. will start but 3 cyl. bad. can a i rebuilb myself, have built car motors all my life, never done a boat motor. just thought ide ask if its a do able thing ?
WillyBWright
Re: merc 150 black max v6
Welcome to iboats. :) <br /><br />There are special ring clamps that you'd need to place the pistons into the block with the crankshaft attached. I don't know if it can be done without those, it's a real trick even if you have them. With at least 3 bad holes, you'd be better off shopping around for parts motors and making one good one from a few bad ones. I think you'd be better off with a 150 V-6. There's no comparing them. Even a 135 V-6 would beat the snot out of an inline 150. If you gotta spend the money, invest in one of those.
studlymandingo
Very doable. Get a really good repair manual. If you follow the directions carefully, you will have no problem. Biggest thing is getting the old bolts out, you're bound to snap a couple of heads off. I like to start soaking them in penetrating oil a few days in advance of the tear-down; you'll still snap one or two. When you do, just be patient and careful, you can drill them out, then clean the threads. Once done with the rebuild, you will have a strong motor that will give many years of great service. Look around for Clams Canino, he's the "tower of power" guru here, he really LOVES the inlines!!!
Clams Canino
They never made an INLINE 6 150 with oil injection. Please clarify what your motor is. :) <br /><br />-W (welcome)
jiml100
sorry guys v6 black max ny mistake....
jiml100
sorry guys my mistake. 150 black max v6. was looking at something else while i was typing...
