merc 150 fouling plugs
Searenity
First of all I hope everyone is enjoying the summer, here in CT it is way too short. I finally got a slip assignment and took my boat out fishing this afternoon on longisland sound..didnt catch much fish, but who cares,wasnt working...any ways heres my question: I have a 150 1986 black max mercury out board on a 1972 Robalo... the engine had some issues but seems to be running fairly well, I never push it, but do try to keep the revs up...it seems I always am fouling the plugs, can i try cutting back on the oil injection pump?? am kinda concerned it is where the manuel says it should be set..but it starts running like poop after a couple of hours. I checked the compresssion at the begining of the summer....was between 90 and 100 psi in all six cylinders..any help on this issue would be appreciated, Thanks Art
sloopy
Re: merc 150 fouling plugs
are you using the wright plugs with the proper gap?
Searenity
Yes I am using the plugs that the mercury manual calls fo , they are not the kind of spark plugs you can adjust the gap on, ..off the top of my head i believe they are NGK BU8H
Searenity
Hi group, just wanted to get this back on the first page, need some advice here, should i try cutting back on the injection oil flow??
Outrage 19
I have heard someone suggest using the regular type plugs instead of the surface gap plugs, as they do not foul as easy.
Searenity
OK, try the other kind of plugs?? is this something that might solve my problem??
