My 150 Merc has been showing an increasing problem. At low RPM shifting into forward or reverse (previously only in reverse) it seems to slip as I shift into gears slowly and noisily and then tends to bang and buck. At high throttle no problem. Seems as if there is play in the system as well as slack in shifting. Motor kicks repeatedly with a thump until I up the throttle. Not sure if the shifting and bucking problems are related or two separate fixes? <br /><br />I read another post to this board that makes me think I might be able to fix this by doing some adjusting at the motor to take out slack when it shifts into gear. Getting ready to take out the wrenches and the manual.<br /><br />Any info on similar experiences and how they were fixed or advice would be appreciated. Thanks.
