Superjetjim
- Jun 5, 2010
- 222
I have a 150 V6 Merc (1981) - when its ticking over I get no water from the pisser or the two exhaust ports.
When I run it at 3,000 RPM in neutral (or in FWD) water comes out of the exhausts (pretty warm to the touch but not hot)
Regardless of throttle no water comes out of the pisser - I have blown down it with the air line and its clear - any ideas?
The engine doesnt appear to be overheating, however I can only run the engine flat out for 60 seconds in either direction on the water I'm testing on (River) before I need to stop and turn around - but no alarm is sounding - would it get hot enough to set it off doing this?
Is this normal - if not what should I change.
I fitted a new impeller a couple of weeks ago - could I have misaligned the main water pipe or somthing? Thermostats are OK - I checked they moved in hot water, cant I just remove them? - My Jetski runs without thermostats and has great pressure from cold.
Thanks for ALL and ANY help.
Jim
Jim
