Re: Merc 165/GM 250 engines
Thanks Daveswaves.<br /><br />ya, I'm sure there are a number of things that would make this too much work. I was hoping.
Next bet is finding a (very) cheap beat up boat with a average/good 165.
<br /><br />As for performance.<br />We have installed new plugs, new cap, new wires, points looked good, no pitting. Dwell was right on. Timing right on. The carb could be the culpret alright. Should rebuild it.<br />There are so many things on this boat that need fixing it's driving me crazy because the owner, a good friend of mine, doesn't have the time to do it. If we could take it out of service for a while it would be much better, it's used to commute all year. Take the hydrolics, still don't work. If we could trim the leg properly I'd bet it would move a lot better, right now the leg doesn't go all the way down so the boat just doesn't quite get over the top on plane and I bet the leg trim is causing it. But I digress.<br /><br />What's concerning me right now is a low down vibration/knock. Sounds to me like a rod bearing.<br />It could be just a lifter or 2 but it seems lower down that that.<br />Anyway, I appreciated the reply.<br /><br />Jeff
