I have read that you must press on the harmonic ballancer for the Merc 165 250ci staight 6 but my Merc Manual says to:
1. Coat front cover oil seal contact area of balancer with contact oil.
2. Attach damper tool J-8792 to damper (looks like a ruber piece) that hangs onto the pulley groove.
3. Position damper and drive into position until it bottoms against the crankshaft gear.
The manual says that for the 292 you must push on the balancer using the threaded crankshaft hole. My crankshaft hole has NO threads and does not look to be damaged. I am worried that driving the damper on my damage the crankshaft...but the instructions say to? Ideas? Comments?
