Drive is off, water (fresh, not salt) in bellows. 3 years ago I pulled the drive to remove the engine. At that time I replaced the main bellows, installed it with 3M weatherstrip cement on the advice of local marine shop. Tightened clamps. Installed drive with new gasket and rubber ring seal. I know now that it started leaking a small amount of water right after that (tiny bit of water would drain from drive, which I did every trip - never enough to turn the gear oil to a milkshake), so something I installed didn't seal right, or my new bellows has a pinhole, which seems unlikely.
Does it seem more likely that the leak is in the bellows, or the rubber ring seal on the drive? I was gonna remove the bellows this morning to check and reseal it, but holy cow, that 3M adhesive has the thing really stuck. I couldn't get it to loosen at all, so I'm thinking, what's the likelihood of that leaking? More likely the drive gasket and ring - maybe? Opinions?
The U-joint assembly is very rusty on the outside but the joints feels good, so I think the rubber seals did their job and kept the water out. I'm going to disassemble and re-grease them anyway. Since water was sneaking past the upper outdrive seal, would it be best to replace it?
Thanks, Jeremy
Thanks, Jeremy
